ORIGINAL: Deandome
Do the Mintor 33 & 38 have the same prop-bolt pattern as the DLE 30/35? If so, can you use the DLE single-bolt adapter that Valley View RC sells (which also works on the PTE-36)?
Also are there any 'wraparound' mufflers that will fit on either engine?
Thanks!
The 33 propeller bolt circle diameter is 29mm, it does not match the DLE30's BCD.
<br type="_moz" />
