RCU Forums - View Single Post - Servo Trays and Push Rods ?
Old 10-02-2012 | 10:43 AM
OldScaleGuy's Avatar
OldScaleGuy
Default RE: Servo Trays and Push Rods ?
ORIGINAL: BillinIndiana
Thanks for all the info and tips!
Edit: One more thing, can the store bought ones like the Sullivan be cut for length? I'm totally new to this so Thanks again!
<br type=''_moz'' />
Yes, the Sullivan push rods can be cut to length to suit the plane you are building. I would suggest going the Sullivan route until you gain further experience and find something that works best for you. After many years i still use them quite often. You really can't go wrong with the Sullivan push rods. Add some support to keep them from flexing and you are good to go.
Typically i use 1/4 X 3/8 bass wood as rails to mount the servos. Most any way you make the servo mounts is ok as long as you do use a hard wood versus balsa wood.
