Hitec X1AC with Sky Lipo problem
Any ideas? I have 3 1600 Mah 11.1 volt Sky lipos and a Hitec charger. Over the last week the charger has started erroring out voltage too high on 2 of the batteries. Upon trying to charge again, I monitor the individual cell voltage and after a short time it starts bouncing all around on the individual cells showing 3-5 volts then errors out again. Think this is a battery charger or Lipo problem? Think it could be a balance board problem? I always charge with the balance board connected and in balance charge mode. When I put a cell meter on the battery after removing for the charger, it showed the cells fairly well balanced. Confused. Thanks for any help.
