RCU Forums - View Single Post - moki with cline regulator problem
Old 10-03-2012 | 01:41 AM
pe reivers
Default RE: moki with cline regulator problem
It's easy to hack away the metal that is not needed. Advantage is that standard walbro Diaphragms and needles can be used.
I successfully used both Walbro pump AND regulator on a ST2300, combined with exhaust pressure on the regulator. A Cline would suffer from lean mixtures in this engine.
