RCU Forums - View Single Post - OS 33GT Gasoline Engine for Pattern
Old 10-03-2012 | 11:50 PM
  #322
aerobear
Default RE: OS 33GT Gasoline Engine for Pattern
ORIGINAL: MTK
ORIGINAL: vatechguy3
can you lengthen the header to smooth out the tranistion?
understanding of course you will lose a little top end as a sacrifice.
tony
Not for CD ignition. Glow responds to such pipe changes but gas doesn't. . Even stretched 3'' there is no difference in engine performance. Stretching any more than that becomes impractical
Would an ignition controlled by the transmitter be useful here? The ignition curve would be programmed in the transmitter. Simple with modern radios. It would seem the close ties between OS and Futaba would make this easy.
I wonder if OS has any pattern aspirations at all. A 44GT rear exhaust would be interesting.
