ORIGINAL: Henk Visser
Hi Guys,
Where do you install the smoke tube?
Just behind the turbine in the thrusttube, or in the back @ the end of the thrusttube?
Any information or pictures would be great :-)
Regards, Henk
I install mine at the rear of the engine, just drill a hole through the jetpipe carbon bell. Also found flattening the end of the tube into a wide slot shape also helps with the smoke production. Don't have access to my UF at the moment but will post pics later if needed, I'm sure plenty can post pics of what you need.
Rob.
