RE: Hitec X1AC with Sky Lipo problem
You can rule out the balancer by charging without the balancer for a short duration. If the erroneous voltage message shows up again, the charger must be bad.
In general, if the balancer is in place during the charge, the voltage per cell seen by the charger will be lower, than if the balancer is disconnected.
