RCU Forums - View Single Post - How much strength does balsa / ply add?
Old 10-04-2012 | 09:46 AM
ameyam
Default RE: How much strength does balsa / ply add?
Additional images attached.
You will note that there are no stringers anywhere. This is just interlocking ply construction.
See the video how the wood flexes with just a little pressure. As stock, this model was meant to fly of tarmac and can take no abuse. The model is 67" span and has come with a 20cc badge. But with a 120ax its tail heavy and I am considering putting a DLE30on it
http://youtu.be/VltvmDt2qwI
Ameyam
ID:	1807803   Click image for larger version
ID:	1807804   Click image for larger version
ID:	1807805   Click image for larger version
ID:	1807806   Click image for larger version
ID:	1807807   Click image for larger version
ID:	1807808   Click image for larger version
ID:	1807809   Click image for larger version
ID:	1807811   Click image for larger version
