RE: Official HPI Savage Flux XS thread...
I've read quite a bit of this but didn't see anyone with the same problem as me. Anyone having problems with wheel wobble? My rear wheels are particularly worse than the front. If i hold the truck off the ground and gas it, all the wheels wobble quite a bit. Running on the street, it dosen't seem as bad until i get to the higher speeds. Then it wobbles quite bad. I treid taking the hinge pin out of the outer a-arm and putting a washer in between the hub and a-arm as it seemed to be where the slop was originating from, but didn't really help. I'll dig into it a little more and see what i can find. Might be the bearings, hexes, or the holes for the hinge pins are wearing (can't see that, just got it less than a month ago and only ran 5-6 2s packs thru it) but not sure. If anyone has any suggestions, im all ears! thanks.
