RCU Forums - View Single Post - How much strength does balsa / ply add?
Old 10-04-2012 | 01:19 PM
speedracerntrixie's Avatar
speedracerntrixie
My Feedback: (29)
Default RE: How much strength does balsa / ply add?
You could put in some 6mm square cross braces to stiffen up the fuse. Basically you would be making a truss structure. This would add alot of strength without much weight. Be careful about adding a bunch of weight and then strapping on a bigger and heavier engine. That is a good recipe for ruining an otherwise good airplane. I think you have done this in the past with some of your other airplanes.
