RCU Forums - View Single Post - PST600R Fails to begin start sequence
Old 10-04-2012 | 03:01 PM
speedbrake's Avatar
speedbrake
Default RE: PST600R Fails to begin start sequence
I replaced the engine with another PST600R. Using the same transmitter, receiver and TEMS as before, the engine started with no problem. So, there is obviously a problem with the ECU or the wiring. This engine has just returned from the factory. Is there a factory representative in the United States or Canada that can look over the turbine and ECU?
Also, I need to replace a propane valve and need the pig tail as well.
cheers,
Keith
