RCU Forums - View Single Post - YS-170CDI Flight Report
Old 10-04-2012 | 07:37 PM
  #548
atul
Default RE: YS-170CDI Flight Report
Alejandro,
Thanks for your reply. I had not thought of the Y-harness approach. I guess an s-Bus connector will work too. I've been using two fairly large batteries (1500 MAH Duralite packs) for the receiver and extracting the ignition power from the receiver direct.
About the Futaba programming - I've still got to try it out. I'm a novice at setting up and using the advanced programming (such as the stick-controlled snaps) so I may need more help there!
Atul
