RE: Finishing for a TF GS P-51D
From the pictures, what I have is definitely too large. I'm going to check with the people I bought them from to make sure they didn't send the wrong decals but the correct instruction set (that's the only place the 1/5 scale is written).
In either case, there are some differences. For example, the picture showing the hatch just above the trailing edge of the wing on the fuselage that says "Coolant Vent" on the pictures you show are worded as "Coolant Filler" on mine. Could that be a difference between British and English wording or something? But if I put both of those on that hatch from these decals, I'd have to make that hatch something like 2 x 2.5 inches. Much larger than it should be from the visuals.
Frets, is that p-51 a 1/5 scale?
Russ
