RE: CDI gr8flyer55
Jake, This thing is the cat's meow!
I love it, and everything works great. Just to prove it for myself, I programmed two curves into a previously unused chip so there was no mixing of data from a preprogrammed curve. Popped it into the timer and tested. Works really nice. Now if the weather holds tomorrow morning, I'll give it a run on the engine and test both curves.
I need to make a good 4 stroke curve for my converted O.S. 60. It was setup for throttle coupled mechanical advance and always stumbled and hesitated at mid throttle settings so I want to see if it can be cured. If it works, Look out Mr. Saito!! Theres a new kid on the block...
Anyone interested in sharing a 4 stroke curve for testing so I have a starting point?
John
