ORIGINAL: aframe2
I have a DX8 Spektrum transmitter and am trying to bind a AR400 receiver. The light in the transmitter
shows steady when I bind the tx to it, but none of my servos will move. Please help. Aframe2
Did you try connecting the Bind Plug to the Bind/Data port, connecting a fully charged battery to one of the Servo ports, wait for the Flashing lights on the Rx, depress the Bind Button on the DX8, wait for the flashing lights on the Rx to go out and come on Solid, check the DX8 display to see that the Bind Process was complete, remove the battery from the Servo port, remove the Bind Plug and power off the DX8?
Connect a servo to the AR400, connect a battery to a Servo port, power up the DX8, and see if the servo will respond to Stick movement.
Keep the Tx a couple of feet away from the Rx when Binding. Be sure the Rx battery is 5v or 6v.
http://www.horizonhobby.com/pdf/SPMAR400-Manual.pdf
