RCU Forums - View Single Post - Jettronics sequencer problem
Old 10-07-2012 | 08:47 AM
tucson
Default Jettronics sequencer problem
There have been other threads on problems with the JT sequencer in the past but none that are answering my problem.
This is my second one. I have another in a Tutor that works fine.
I am using two JetTronics electronic valves one for gear and one for doors. The valves work fine with the gear switch on the transmitter.
The problem arises when I tie the two valves in with the Sequencer.
I cannot get the sp (switching point) function to set the gear position by pressing the + or - button.
I cannot get the G function to work with raising or lowering the gear with the gear switch on the transmitter. The + and - buttons do not work.
Time delays do not appear to work (maybe a slight change).
And it does not stay in the proper sequence with the gear switch on the transmitter.
I have used the reset button several times on both the Valves and the sequencer.
I have spent 3-4 hours trying everything and then going back to square one and starting over.
I believe the sequencer valve may be bad, but I am not ready to give up yet.
It could be I am doing something wrong in my setup.
Any help at this point would be greatly appreciated.
Stan
