RCU Forums - View Single Post - Jettronics sequencer problem
Old 10-07-2012 | 12:56 PM
tucson
Default RE: Jettronics sequencer problem
ORIGINAL: Dave Wilshere
Stan
Reset the valves to factory. Plug servos it to test the sequencer, once you know the sequencer is doing what you want the valves are either working or not.
I never program the JT valves, I just use them how they come.
On my Hawk I use the DSX-12 Tx delay to sequence the gear and door JT valves..
Dave
Hi Dave,
I did reset the valves to factory(several times).
I did hook a servo up to doors and gear to make sure they were working, they worked okay. I never did program the valves.
The sequencer is the problem. The time delay does not work, as well as a few other things I mentioned in my original post.
I did as you did I originally used my 12x Tx delay to sequence the gear and door JT valves. It worked great.
The reason I went to the sequencer was to free up a channel for smoke.
I just removed the sequencer and am going back to using the servo delay for the gear and doors.
I am going to use the new pump I just bought for smoke in my Tutor. It has a JT sequencer that works.
Thanks for the input,
Stan
