RE: Finishing for a TF GS P-51D
Thanks folks, I'm going to try the cheapest option first. Picked up some clear contact paper last night. I'm hoping I can cut it with my cutter.
If that doesn't work, I'll probably go with the Oracal.
Chris, I've never worked with Frisket Film. Do you think it could be cut on a cutter machine? I have to say it is so much easier to do that
than trying to cut out the pattern on the plane.
I think I'm going to do a quick test and see if I can replicate the decals I have on the scoop, only a bit smaller. If that works on a test
piece I'll probably remove the decals and go with paint. That would actually be easier to distress anyway.
Russ
