ORIGINAL: proanti1
ORIGINAL: Anthoop
Higher octane fuel allows more advanced ignition timing...if you have a lower octane fuel than normal then you will need to retard the ign timing to prevent pinking.
It's purely about compression, not timing.
The pinging is the fuel igniting under compression.
WHICH can be affected by modifying the timing.
