I also had some slack ... I opened, cleaned everything, and pressed more screw wheel, not much has changed but decreased slightly.
In the rear hub, I put a wedge in the bearing. Or even a ribbon around. Help a little.
[youtube]
MaRskOb8U9o[/youtube]
ORIGINAL: cumminspower5.9
ORIGINAL: ejc34710
Just kind of an FYI. Things are going to wobble a little bit. Nothing can fit tight, otherwise there is no room for shifting or movement in the pivoting points. If your drive cups have failed and wrecked the rear upright or front C-hub, that will cause a lot of play. But I can't see your cups failing in 5-6 packs.Your front will wobble just a bit due to the slop in the steering system, that's normal. we will know more when you get the video up. Make sure you get the wheels wobbling at all angles. And pop a wheel off and move things around with your hand so we can see which parts are moving and how much.
No, this thing wobbles baaaad. And its getting worse. The rear right is th worse. Even on a 2s, speed runs are...... kinda crazy due to crazy wobble. I'll get a vid up soon. My T-maxx and Savage X have way less wobble than this thing. Looks like a combination of things. Ill have to take it apart soon so i can get a better look at it. Been into RC for 20 years, from helis to boats to planes to cars, something is definatly up. So far, not too impressed with this XS....
Yea with a vid we'll be able to tell better. The wobble issue is small compared to what other people are having with their XS's. I had the esc issue, but got it replaced. Other than that, only normal parts Ihave replaced.
