RCU Forums - View Single Post - CDI gr8flyer55
Old 10-08-2012 | 03:08 AM
  #484
nyemi
Default RE: CDI gr8flyer55
<span lang="en" id="result_box"><span class="hps">Hi,</span> <span class="hps">everyone</span>
<span class="hps">Sorry</span><span>, but</span> <span class="hps alt-edited">work</span> <span class="hps">does not leave</span> <span class="hps">me time</span><span>.</span>
<span class="hps">Specifically</span> <span class="hps">I'm sorry</span> <span class="hps">you:</span> <span class="hps">Gompy</span>
<span class="hps">Printer</span> <span class="hps">circuit board is</span> <span class="hps">still experimental</span><span>:<span lang="en" id="result_box"><span>docs.google.com/file/d/0BxQHqG9HPIj3bV9HZnRWbXdHUDQ/edit</span></span></span></span><span lang="en" id="result_box">
<span class="hps">I use</span> <span class="hps">Sprint</span> <span class="hps">Layout</span> <span class="hps">5.0</span>
<span class="hps">I</span> <span class="hps">see</span> <span class="hps">Jake</span><span>'s success.</span>
<span class="hps">Congratulate him.
</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box" class="short_text"><span class="hps">Great work</span><span>.</span></span></span>
<span class="hps">If you</span> <span class="hps">have a</span> <span class="hps">little time</span><span>, and then</span> <span class="hps">look through</span> <span class="hps">C code</span><span>.</span>
</span><span lang="en" id="result_box"><span class="hps">Now</span> <span class="hps">a</span> <span class="hps">lot of</span> <span class="hps">work</span><span>,</span> <span class="hps">busy.
</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box" class="short_text"><span class="hps">It is difficult</span> <span class="hps">for them</span> <span class="hps">to life.</span></span>
</span></span><span lang="en" id="result_box" class="short_text"><span class="hps">I welcome all</span> <span class="hps">ignition</span> <span class="hps">constructor</span><span>.
</span></span><span lang="en" id="result_box" class="short_text"><span lang="en" class="short_text" id="result_box"><span class="hps">Large</span> <span class="hps">sparks.</span> <span class="hps atn">Easy-</span><span>starting</span> <span class="hps">engines.
</span></span><span class="hps">Good luck</span><span>.</span></span>
