RCU Forums - View Single Post - CDI gr8flyer55
Old 10-08-2012 | 03:30 AM
  #485
Gompy's Avatar
Gompy
Default RE: CDI gr8flyer55
ORIGINAL: gr8flyer55
Rob,
What sparkplug size does your Aprilia use? 5/8 hex or 3/4 hex? I'm building another ignition for you to try..finished the whole ignition for your homelite engine complete with plug wire and a case..just like I sell. If you'd rather I left the sparkplug cap and boot off, I can do that also, but tell me the wire length you'll need..
Hi John,
For the Aprilia I need a hour to see how long the lead must be.
The ignition and candle are behinde the airfilter and other bodywork.
It's a crime to replace the candle, you can't doit if you are on the runway.
I think / hope 10 or 15" will be enough, otherwise I replace the ignition.
For the Homy I think I have enough of normal lenght.
The flashlight.
The flashlight wil be triggert at the same time the SCR is triggert.
But why want you change it, the LED do the job very well (I think ?)
If you want a "tool" for it, put a LED into a (alu) tube, and you have a real strobe.
........or have you make a board change on the pin output of the flashlight ?
