RE: THE NEW CERMARK F-16 BUILD IT BETTER, STRONGER, AND FASTER!!!
OK, retract mounts beefed up and gear installed. I am working on the stabilators now. The aluminum tubes are quite tight in the bushings. I certainly will not do anything to bore them out so the only option i know of is to lubricate them a bit. Any suggestions here? I have no doubt that my servos will be growling if i don't do something to loosen them up a little. Also, anyone made the stabilators functional and was it worth it? My Futaba 10C can make them operational.
