RCU Forums - View Single Post - Let's gasify a Vanquish
Old 10-08-2012 | 07:37 AM
MTK
Default RE: Let's gasify a Vanquish
ORIGINAL: cmoulder
Can't wait to see how you put a nose ring in that light cowl, Matt!! But I know you will solve the problem.
Eagerly awaiting your reports,
I'll post some photos tonight on how I've captured the cowl. Much more secure than the original. Both the cowl and canopy are heavier than I want or is needed. But I probably won't build new molds for those parts unless the plane comes out too heavy.
The biggest issue is the prop drive hub....it is larger than the crankcase so the nose ring will be designed as a two piece unit.....
