RCU Forums - View Single Post - Bolt on axle
Thread: Bolt on axle
Old 10-08-2012 | 06:41 PM
Gray Beard
My Feedback: (-1)
Default RE: Bolt on axle
John, he just said his CG is good, nothing about changing it. However, bigger wheels will weigh more and change the CG. If you have bolt/screw on LG then it is simple to change the axels. Most the time it is just a mater of drilling out the center hole in the wheel to make them fit the axel. They can be drilled so they are very thin on the inside without a problem.
