RCU Forums - View Single Post - Let's gasify a Vanquish
Old 10-08-2012 | 06:47 PM
MTK
Default RE: Let's gasify a Vanquish
Cowl needs better reinforcement and mounting. The way the VQ is done, it makes this task simple. The cowl will eventually house a nose ring so a better mount than stock E-type is required
In the second photo you can see where the fuse sides were covered over with some 1/32" A/C ply. The stock sides are 1/16" laser cut ply, heavily cut to save weight. It works on the electric but I didn't want to take a chance on this conversion. It adds 3 grams but adds tremendous strength to the original ply
It's a good idea to reinforce the fuse top by adding a cross top of lite ply, boxing the front end in. Even soft mounted, engines shake of course so judicious use of reinforcement is a must for long fuse life
ID:	1809567   Click image for larger version
ID:	1809568   Click image for larger version
ID:	1809569   Click image for larger version
ID:	1809570   Click image for larger version
