RE: A10 dissapointment
Thanks for the quick input. Talked to another and they use the 2s1p (1200) for the A-10 with good results. Additionally they also used the 2S2P pack (2400mAh!) pack for extended times on the A-10 and for the GWS Corsair with the 350 motor and 10x8 prop. Thanking about 2s1p for A-10 and then double up for the corsair.
If I used the 2S1P Thunder Power 2100 mAh also on the corsair would this be the same as the 2s2p 2400. Trying to get the most out of and the less expense and still do the job. I am totally new to these batteries.
Bill
