ORIGINAL: Kevin Morris
What a beautiful Baron you have too! How did you make your seat belts and nose gear light? On my Baron Doors I used two robart nose gear hinges and the rear doors I used Brass hinges from a doll house store since I was unable to get the rear doors to work with the same range as the real airplane.
THX!
For the seat belts I've choosed some gift tapes (? google-translater...) and the taxi-light is simply glued on the oleo strut for cooling (!) instead of a cooling body, which comes together with the landing light, cause it's going to be very hot !
For lighting please google "emcotec" -> "lighting" -> "landing lights" -> "12 mm Landing light" (direct-link doesn't work) , unbeleavible extreme bright SMD emitters.
Additional landing lights will going into the wings, like older Baron-styles - looks much more interesting on final aproach, I think...
The Brass hinges are the way to go - looks very "aviation-like" !!
