RE: Evolution .45 alpha trainer engine runs backwards
Kirk,
don't you have something to program?[8D]
As Kirk said, it is not uncommon for engines to run backwards when new. What is probably happening when you start it is you hit the compression stroke and it kicks backward and runs the wrong way. If you are using a chicken stick to start, be sure to follow through on your flip to get it going the right direction.
