RCU Forums - View Single Post - connectors
Thread: connectors
Old 10-10-2012 | 12:55 AM
JohnBuckner's Avatar
JohnBuckner
Default RE: connectors
ORIGINAL: gphil
Now if I do that when removing the wing for transport have to disconnect two servo wires and hate to do that. Is there a connector for this ? like two plugs in and two out going to receiver? If not then either a ''Y'' harness or work with two wires. Just wondering. gphil
You have just discoverd the down side to using each aileron servo in a different channel. Yes you can Y both ailerons servos and only plug to one channel to simplify assembly/disassembly. On some airplanes I do use a channel for each aileron and on others which have many other things going on, some up to five plugs that need to be plugged each time I often will run the ailerons on only one channel to reduce the chores at assembly time.
John
