RE: what's the advantage
If the exhaust residue is black the engine is either over compressed or lean or both. The exhaust residue should be amber in color. The Davis conversions seldom need the compression tweaked after the initial setup unless there is drastic change in ambient temp or you change props. What fuel are you using?
