ORIGINAL: papaone
Hello Matt
Which exhaust system will you install ?
I'm looking for a rear exhaust header for this PTE36R .
Claude
Claude,
The OS140RX header fits nicely, except the mounting holes need slight modification. They need to be opened for M5 mounting bolts and moved out about 1mm on each side.
<span style="font-size: larger">
EDIT: The Macs header for the OS140RX ,not the 2 piece one OS makes..... Actually Macs makes 3 headers for 30-40 cc rear exhaust gas engines as shown on their website. It may be that one of them would be a drop in choice. I'll measure the bolt CL dimensions of the exhaust flange and see if one of them will work
</span>I'm planning to use a Mintor pipe on mine. I will start with an XOAR 19x10 laminated prop for break in and move up from there if the engine can tolerate it.... I'll post some photos when I have progressed enough with the pipe tunnel to warrant it
