RE: Another newbie question..savage x4.6.. When putting clutch bell on will u see a little clutch pad
Is the flywheel tight on the collet? You should be able to hold the flywheel and tighten the black nut down on it. I had an issue with my Savage x when I first got it. The collet welded itself into the flywheel so it wasn't able to grip the shaft. everything shifted forward and the clutch springs got shreaded.
