RCU Forums - View Single Post - Need Help with Fox 15 Davis Conversion
Old 10-11-2012 | 07:36 PM
  #74
fiery
Default RE: Need Help with Fox 15 Davis Conversion
Yes.
However it has not been established that the fit of the piston to liner is the problem. Is compression leaking down significantly when the engine is cold and turned over slowly?
It should hold compression and "push" the piston down as you take it over tdc.
As Mr Davis says in his printed instructions, his conversion head will not perform well with a worn engine.
