RCU Forums - View Single Post - JS 7 Heavy Tank
Old 10-12-2012 | 03:57 AM
pattoncommander's Avatar
pattoncommander
Default RE: JS 7 Heavy Tank
The M-41 turret is too small, welded construction and angular. The 47 was molded with mostly rounded features. The bustle box is also smaller and not nearly as deep. Basically a similar design but M-41 was a bit wider and squat where the 47 stood taller due to the range finder and newly designed 90mm recoil system.
Having written that, it could probably be used as a base. I used the T-34/85 turret for the Egyptian T-100. A good, firm base makes an easier job.
ID:	1810460   Click image for larger version
