ORIGINAL: chistech
I used the wingspan of the 40 size Zero and not the Rufe. The Rufe has a 1490 span. By comparing 40 zero to 60 zero I should be OK I believe.
This where I get confused, how can the have the same scale and wing span when one should be a bigger span than the other, if the Rufe and the 40 size are truly both 1/8 scale, the Rufe should have about a 9% larger span
MTK-001 Mitsubishi A6M5 Type 0 model 52 "ZERO" or "ZEKE" FIGHTER 1:6 WS 1592mm 3.2- 3.5 Kg .60 2 cycles engine
MTK-002 Mitsubishi A6M3 Type 0 "ZERO" or "ZEKE" FIGHTER model 22
1:8 WS 1480mm S 37,5 dm² Weight 2,6- 2,9 kg .40 2 cycles RC 3 - 5 servos
MTK-004 Nakajima A6M2-N "Rufe" FLOATPLANE: FIGHTER based on A6M-2 Model 11 with modified tail and floats.
1:8 WS 1480mm S 37,5 dm² 3,2 -3,6 kg .60 RC 4-5 ch.
The way I've figured doing it is to add 9% to the a6m5 60 size wing span, then do the math compared to the Rufe, try that and compare realitive to the three views and see what you get
