RCU Forums - View Single Post - Let's gasify a Vanquish
Old 10-12-2012 | 08:23 PM
MTK
Default RE: Let's gasify a Vanquish
And the pipe mount treatment. I use one Lord mount to hold the pipe.
The balsa was undercut to recess most of the Lord into the fuse. Nothing fancy is needed here. A piece of 3/32" A/C ply inside the fuse with drilled and tapped mounting hole works fine and has stood the test of many a flight. A blind nut is not necessary. Try it!
ID:	1810683   Click image for larger version
ID:	1810684   Click image for larger version
