RE: Royal Zero Kit Build into Rufe
Yeah, see this is why I suggest comparing fuse lengths, not wing spans or scale%,, those might not be 100% accurate as to scale 3-view,, And as you know, when setting up a float plane, float length is relative to the fuse length anyway.
Now with that 15% you've determined, add that to the fuse length of the Rufe (say spinner back plate to tail) and see if it match close enough to the length of the 60 size A6M5 fuse, if they match up you have your multiplier.
