RE: Royal Zero Kit Build into Rufe
Going by Wizard's 12000mm Rufe span it means the Sr. Zero's 1592mm span needs to be increased 7.69% to reach the 12,000. The wingspan if exact scale would then be 1,714.2mm at 1/7th scale. Doing the math previously in another post, it is pretty close so no need to do it again. Will look at Gerry's Sr. Zero plan and my Rufe plans then compare the fuse lengths. This should then help determine what percentage of increase needed like Scale only for me suggested.
