RCU Forums - View Single Post - CDI gr8flyer55
Old 10-13-2012 | 09:44 PM
  #526
nyemi
Default RE: CDI gr8flyer55
Hi bluejets
<span lang="en" id="result_box"><span class="hps">I called</span> <span class="hps">Jake</span><span>'s attention.</span>
<span class="hps">The</span> <span class="hps">bounce</span><span>-free</span> <span class="hps">input.</span>
<span class="hps">This</span> <span class="hps">Software</span> <span class="hps">can</span> <span class="hps">be solved.</span>
<span class="hps">The</span> <span class="hps">hardware</span> <span class="hps">is not</span> <span class="hps">bad</span><span>.</span>
<span class="hps">But</span> <span class="hps">not enough.</span></span>
<span lang="en" id="result_box" class="short_text"><span class="hps">Find a</span> <span class="hps">good solution.</span>
<span class="hps">link:www.labbookpages.co.uk/electronics/debounce.html</span></span>
<span lang="en" id="result_box"><span class="hps">I</span> <span class="hps">checked</span><span>, Jake</span> <span class="hps">Code</span><span>.</span>
<span class="hps">I'm</span> <span class="hps">curious</span><span>.</span> <span class="hps">Jake,</span> <span class="hps">that</span> <span class="hps">solved the</span> <span class="hps">problem.
</span></span><span lang="en" class="short_text" id="result_box"><span class="hps">I</span> <span class="hps">compiled</span> <span class="hps">ASM.</span>
<span class="hps">I</span> <span class="hps">see everything</span><span>.</span></span>
