RCU Forums - View Single Post - DA Ignition Module
Old 10-13-2012 | 09:59 PM
stroker280
Default RE: DA Ignition Module
Thanks for the reply mate. Hows everything down under. I will try that tomorrow. I had a concern about grounding the plug or a screwdriver like you mentioned but I will give it a try. I didn't replace the hall sensor because the only part online I could find for a DA-50 was the ignition module and the prop hub. I also have the RCexl conversion I bought for this motor also. I will call Chief on Monday if I find the new module I just bought is bad.
Thanks again
Jeff
