Hi bluejets
<span lang="en" id="result_box"><span class="hps">Yes</span><span>, the circuit is</span> <span class="hps">good.
</span></span><span lang="en" id="result_box"><span class="hps"><span lang="en" class="short_text" id="result_box"><span class="hps">Part</span> <span class="hps">solves</span> <span class="hps">the problem.
</span></span></span>
<span class="hps">But</span> <span class="hps">this is not</span> <span class="hps">causing the problem.</span>
<span class="hps">The software does not</span> <span class="hps">turn off</span><span>,</span> <span class="hps">the input</span> <span class="hps">pin (GP2) of the</span> <span class="hps">interrupt</span><span>.</span>
<span class="hps">When the</span> pin <span class="hps atn">(</span><span>GP2</span><span>)</span> <span class="hps">of the signal</span> <span class="hps">is displayed.</span>
<span class="hps">I do not</span> <span class="hps">know.</span> <span class="hps">Jake,</span> <span class="hps">why do not you</span> <span class="hps">use</span> <span class="hps">IOC</span> <span class="hps">register (INTERRUPT-ON-CHANGE GPIO REGISTER)</span><span>.</span></span>
<span lang="en" id="result_box"><span class="hps">The</span> <span class="hps">opportunity exists</span> <span class="hps">to</span> <span class="hps">separate</span> <span class="hps">interrupt</span> <span class="hps">handling</span> <span class="hps alt-edited">pins</span><span>.
</span></span><span lang="en" id="result_box"><span class="hps">I'm sorry</span><span>.</span> <span class="hps">I</span> <span class="hps">now see</span> <span class="hps">GP4</span><span>-5</span> <span class="hps">pin</span> <span class="hps">interrupt</span> <span class="hps">is not</span> <span class="hps">used</span><span>.
</span></span><span lang="en" id="result_box"><span class="hps">It seems to me</span> <span class="hps">that in this case</span> <span class="hps">the</span> <span class="hps">register</span> <span class="hps">INTCON</span><span>,</span> <span class="hps">INTE</span> <span class="hps">bit</span> <span class="hps">is</span> <span class="hps">enough to</span> <span class="hps">delete</span> <span class="hps">it</span><span>.
</span></span><span lang="en" class="short_text" id="result_box"><span class="hps">The task is</span> <span class="hps">waiting for</span> <span class="hps">him</span><span>.</span></span>
<span lang="en" id="result_box" class="short_text"><span class="hps"><span lang="en" id="result_box" class="short_text"><span class="hps">I was</span> <span class="hps">debugging</span> <span class="hps">and testing</span></span></span><span class="hps">.
</span></span>
