RE: DA Ignition Module
Mark
Just got home from work and ran outside to the shop and checked like you mentioned. Your right it's definately the hall sensor. I had the spark plug out and spun the motor over with the elec. starter and moved the wires around on the hall sensor andthe plugstarted firing. Both modules are fine. I didn't even need a new one. I was trying to check the modules with the RCexl module tester. It doesn't work with the DA modules. It works great with the RCexl modules and that was what had me puzzled. Also when you check the voltage out on the DA modules with a multi meter the voltage read was .06 volts. Not the full voltage of the battery either. Thanks for the help mate. I will have two new hall sensors on the way Monday. Hope this helps anyone else having problems with their modules.
Jeff
