RCU Forums - View Single Post - Shorter Spark plug for G62 Question
Old 10-14-2012 | 04:39 AM
BadAzzMaxx
Default RE: Shorter Spark plug for G62 Question
The BPMR6F plug is no shorter than the plug you have now.
I get asked this question a lot and the only way as I know of is to use a 14mm to 10 mm plug adapter and use CM6 plus or 14mm to 1/4 32 adapter and use 1/4 32 spark plugs.
But to do this you have to use a shielded ignition system because the CM6 and 1/4 32 spark plugs are not a register plug.
The draw back to the 1/4 32 plugs is they do not last as long as a BPMR or CM6 spark plug.
Milton
