RE: Royal Zero Kit Build into Rufe
Ted,
There is no dimension called out on the three view(actually a 5 view) for just the length of the fusalage, not including the Float. The text of the book says the A6M2 Fusalage is 9,050 mm in length, but when I scale the three view of the rufe it works out to be 8,694 mm roughly, which would be 342.28 inches full scale. So at 1/7th scale the fusalage should be between 49.10" and 50.89" depending on which figure you go with. If you are interested in a copy of my 5 view, PM me your e-mail and I'll take it to work where I have a better quality scanner and set you up with a set.
James
Wizard61
