RCU Forums - View Single Post - Start problem help
Old 10-14-2012 | 01:08 PM
Dave Wilshere
Default RE: Start problem help
Sounds low hours, but I have seen pumps die at various hours, lots affect this, starting with a ball tap closed/blocked system, fuel with excess moisture leads to corrosion and tight gears. Not easy to change as the drive gear needs removing. Like you say you can use it for other uses.
Dw
