Hi Jake
<span lang="en" id="result_box"><span class="hps"><span lang="en" id="result_box"><span class="hps">You</span> <span class="hps">do not</span> <span class="hps">deal with</span> <span class="hps">the Hall</span> <span class="hps">signal</span> <span class="hps">length.</span>
<span class="hps">If</span> <span class="hps">the signal</span> <span class="hps">is too long</span><span>.</span> <span class="hps">The</span> <span class="hps">interrupt</span> <span class="hps">is generated.</span>
<span class="hps">Because</span> <span class="hps">of the</span> <span class="hps">long</span> <span class="hps">signal</span><span>, electronic</span> <span class="hps">smog</span> <span class="hps">is present</span><span>.</span>
<span class="hps">To overcome this problem</span><span>.</span>
<span class="hps">If the input signal</span> <span class="hps">for sure.</span> <span class="hps atn">(</span><span>GP2</span> <span class="hps">control,</span> <span class="hps">after</span><span>)</span>
<span class="hps">Clear</span> <span class="hps">INTCON</span> <span class="hps">register,</span> <span class="hps">INTE</span> <span class="hps">bits.</span> <span class="hps atn">(</span><span>INTCONbits.INTE</span> <span class="hps">=</span> <span class="hps">0
</span>
<span class="hps">The output</span> <span class="hps">delay</span> <span class="hps">after</span><span>.</span> <span class="hps atn">(</span><span>GP0</span><span>,</span> <span class="hps">GP1</span> <span class="hps">default)</span>
<span class="hps">Turn</span> <span class="hps">on,</span> <span class="hps">again</span><span>.</span> <span class="hps atn">(</span><span>INTCONbits.INTE</span> <span class="hps">= 1</span><span>
</span>
<span class="hps">With this</span> <span class="hps">problem solved</span><span>.</span></span></span><span>
</span></span><span lang="en" id="result_box"><span class="hps">Hungarian</span></span>
Ön nem foglalkozik, Hall jelnek hosszával.
Ha túl hosszú a jel. Az megszakítást generál.
Mert a hosszú jelben, elektronikus szmog van jelen.
A probléma megoldása.
Ha a bemeneti jel biztos.(GP2 ellenĊrzés, után)
Törölje INTCON regiszter, INTE bit. (INTCONbits.INTE = 0
A kimenet késleltetés, után. (GP0-GP1 alap állapot )
Kapcsolja csak, újra be.(INTCONbits.INTE = 1
Evvel a probléma megoldva.
