RCU Forums - View Single Post - How to loosen hinges
Old 10-14-2012 | 02:36 PM
JPMacG
Default RE: How to loosen hinges
Acetone will dissolve CA glue. Alcohol (including ethanol, methanol and isopropyl) will not. If you used epoxy you may be able to scrape it off the hing joint with a small blade. Pretty much nothing will dissolve epoxy.
