RE: Muffler has an effect on idle and transition?
When you remove the restriction of the exhaust, it will lean the engine out. The carb will need to be retuned and richened up a bit. A GLOW engine will idle and transition better with a bit of muffler pressure because it helps keep the glow plug hot at an idle, but a gasoline engine does not need any back pressure from the muffler at all. Power can be increased by using a tuned pipe, or expansion chamber, but that is a different subject entirely. Some people think a gas, ignition engine needs some back pressure, but it is simply not true.
AV8TOR
