RE: CDI gr8flyer55
Well Rob,
You should not have to. You have a pretty cool setup.... don't you?
Jake and all the rest This circuit has been around for 30 years or more and it is pretty bullet proof. I think that if something is causing the transistor in Johns HV board to draw too much amperage then it has to be in the software. I have 50 timer boards by different people and not one has caused this sort of problem. It all comes down to how you control the pic output. I will say that the commercial timer boards that I have do not work like this software.
Jake I sent you some screen shots of the input vs output from a commercial unit. and they all pretty much work the same and none have ever caused this sort of problem. I will stand by and see what you guys come up with.
